Hot wheel issue Not Solved!!!!
To my frustration on last trip found wheel hot again. At a Loss. Pulled over mid trip and found brake drum 300F plus. Other 3 where 130 to 150F range. Disconnected wire to brake in question. Back and forth a few times to release brake. Traveled another 10km and even hotter than before. 330F plus! Crawled under and backed off brake adjuster at least 2 full turns. No time or interest to trouble shoot on side of highway. Cold after that!
The hot wheel brakes were adjusted the same as the other 3. I have a couple ideas:
1)That tire is different than other 3. Previous owner had flat and installed a higher weight rated tire. Don't have exact details but I believe it can carry about 800lbs more and can handle 80psi instead of 60psi. I should put spare on and try again. Maybe odd ball tire is having some kind of vibration effect? But I am having a hard time with this reasoning.
2) The brake or hub is defective. Weak spring or shoes and/or drum deform when heated.
Either way, that was the last camp of the year and I have no intension of playing with it anymore. I would like to have all 4 brakes working, but honestly I did not see much of a difference with only 3. Maybe next season I will tackle again or have somebody else do it as I have had enough messing with it.
So obviously the greasing of the backing plate did not fix as noted before.
Tim
