TheGrinch
Mar 19, 2014Explorer
chezmoose wrote:
We've never used a battery in our PUP. We just used lanterns and battery lamps for light, and coolers for food and drink. Ours did not have a water pump or a fan on the furnace (40 years old!), so never really needed power. I'm assuming we'll need a battery upgrade for the new TT just to run the water pump and fridge(?). Am I correct in understanding that the fridge still uses a little power even when running on propane?
What about under the stabilizer jacks? Do we need any type of pads on soft ground? We just used chunks of 2x4 on the PUP.
The new TT should come with an adequate battery for your electrical needs - fridge(on propane) and water pump included. If you dry camp, you'll need some sort of means to recharge the battery every couple of days. If you're using your shore line, the battery should recharge automatically while plugged in.
I use some small 4"x4" decorative pavers for under my stabilizers. I'd use something a little wider than a 2x4.
On an earlier post, you asked about between wheel chocks..... our first trip in our Roo 23SS, we didn't have the between wheel chocks. DW was frantic about the movement. I ordered the appropriate items when we got home and haven't been without them since. But, that's your call - chock your wheels and see what you think.
Larry
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
