- burningmanExplorer IIIn the article the guy says - correctly- that it would be awful tall if he mounted the camper above the cab.
If you already have the camper, and you already have a retired 379 sitting in your back yard, and you don’t want to buy an expensive new truck, this made plenty of sense.
I personally LOVE the way a 379 cruises. - Grit_dogNavigator IIILol, some of you folks are simply amazing....
I know most folks on here are old(er). But Didn't your mama ever say something like "better to be thought a fool than to open your mouth and remove all doubt?" - Kayteg1Explorer IIThe deal with such project is that they already had the truck, they have friend who did the paint job for low cost and being retired- they could afford to pay themselves 10 cents/hr.
Over a decade ago I was considering converting one of city buses into luxury motorhome. You can buy city bus for like $4000, but it will have low gearing.
Interstate cruisers are much better start. But doing the search, I found several such projects, where somebody sink 2-3 years of work into - available for sale for $5-6.000.
Lot of people start such project only to find it overwhelming and tired by wife constant whining about the monster sitting on the yard- they sell "90% finish" project well below the money they sink in it.
Sure the owners of big rig can't turn it, or park the it where I can my F350, but then no worry about carrying extra water, or extra set of undies. - adamisNomad IIImpressive to say the least that someone went through the effort to build this. I think it would have looked better had the camper been placed above the cab just like it would on a pickup. Aesthetically it just looks a bit unbalanced having it hanging so far back like it does. Of course doing that would have eliminated the extra compartment for whatever toys they may be hauling. Getting that through most campgrounds would be a huge pain if the turning radius is as bad as some say.
I'm kind of torn with it. If this was a low cost build I suppose it could be worth it but if he spent any significant amount of money on it I don't know if it would be worth the expense. If a lot of money was to be spent on something like this, I think I would have built a custom shell and built out the enterior to my spec. A lot more complicated but the lines could be designed to make it look right. Heck, maybe just starting with one of those FEDEX custom rigs for special shipments.
At any rate, if they guy is happy and proud with it, good for him. Always great to see people take something they are passionette about to the next level! - 54sudsExplorer
burningman wrote:
I think it looks just as good or better than a camper strapped on the back of any other truck, pickup or whatever.
Go read the article, link to it is in earlier post. You’re out of line, bordering on ignorant calling it a “hack job”, it’s a very nicely built rig.
That truck can go 20,000 pounds on its rear axle, with those tires, in the U.S. He’s in Canada where it’s legal to go even more. The truck and those tires are easily capable of it safely. He has NO gvw issues.
Why the sleeper? It makes the truck cab a lot roomier. You can seat more than two people, you have room for stuff, and it’s an extra bed if needed or wanted.
its a true truck camper /very versatile /changeable set up that no other RV type can match!!! - burningmanExplorer III think it looks just as good or better than a camper strapped on the back of any other truck, pickup or whatever.
Why the sleeper? It makes the truck cab a lot roomier. You can seat more than two people, you have room for stuff, and it’s an extra bed if needed or wanted. - 05btdvwExplorerWikel,
Wow, go easy until you maybe know a little bit more about the build. If you click the link it does tell you in more detail about the specs. Unlike what you said, it is on a semi rear axle with class 8 super single semi tires.
Probably wrong on the POS pickup type gear you're thinking it had huh?
Edit
Now my post doesn't make as much sense since you edited yours and took out some of the wording. All good. Hopefully the owner of this build is happy! - 05btdvwExplorerQuote mistake.
- WikelExplorer
Kayteg1 wrote:
Aren't semi's axle rated in the range of 20,000lb ?
Sure no problem with 6000 lb camper.
Aesthetic with camper have been mentioned before - in stable loads topic for example.
You want aesthetic in RV - you buy DP with zebra paint scheme on it.
I still think the above set is prettier than some new cars you seen on the roads.
Or famous Pontiac Aztek for example.
Maybe I'm missing something because it's hard to tell from the picture. Looks like it sitting on a hacked off truck rear bed. Maybe it's just the shell of the bed vs. the frame, axle and original wheels/tires. - wnjjExplorer II
d3500ram wrote:
With a complete camper behind, why the need for a sleeper?
Probably the easiest way to plug the hole in the back wall of the cab, plus the frame would need to be shortened without it.
44,056 PostsLatest Activity: May 04, 2014
