mr_andyj
May 22, 2021Explorer
All you need is the water heater with the plumbing for the engine coolant and some heater hoses to run the coolant back to the heater. Heater hose is not going to be a cost consideration on this project. The risk is that your engine now has more places to leak coolant.
Yes, it is nice to have hot water after driving.
Sure, it will get cold eventually, or will run out after use.
I had a class c and the fresh water tank was under the floor and next to the exhaust pipe; 35 gallons. After a long drive the water would be warm enough for a shower, all 35 gallons.
Yes nice.
To save water a cold shower does the trick.
To use a lot of water then a warm shower does the trick.
Can I talk you out of a school bus?
Have you checked the price of just one tire?
I owned a 3/4 ton truck. Everything is more expensive to replace and work on. I can't imagine something bigger being cheap to own.
Consider something more reasonable. A truck and pull a trailer, or buy a box van and convert that, it at least has normal automotive parts and tires.
Yes nice.
About RV Newbies
