KD4UPL
May 22, 2021Explorer II
What your proposing is quite common and normal in motor homes and yachts. The water tank with heat exchanger should be readily available from an RV supply, if not certainly a marine supply house.
You would want to locate the tank near the engine to simplify plumbing it into the cooling system. Don't put it near the tailpipe, that's not where you're getting the heat from.
About RV Newbies
