wa8yxm
May 23, 2021Explorer III
There are a few heat exchange systems
Motor aid
Aqua Hot
And I think one with Hydro in it's name
All work much the same. Engine heat heats the water heater water when engine running.. Shut down and the coolant lines do not flow (well very low if any flow) Get ready to leave you can turn on an aux pump and now hot water pre-heats the engine (Also very useful) safely giving you a warm. or warmer (120 give or take a bit) engine to start and shorter warm up time.
But now you have names to google (Try Hydro Heat for the hydro version though I suspect aqua-hot will hit 'em all)
Motor aid
Aqua Hot
About RV Newbies
