ScottG
Apr 15, 2017Nomad
donn0128 wrote:
Nothing. The lens is a snap on and it needs some opening to allow condensation to drain out. If your really worried, snap then off each spring, clean with a rag or paper towel and snap back on.
Be sure to seal between the light and trailer body.
X2. Your only going to have problems if you try to seal them entirely. When they eventually do get a little moisture in them its just going to go inside the wall.
In our case Forest river put just a small amount of sealant across the top of the lens - which seems to work OK.
About RV Newbies
