MitchF150
Apr 15, 2017Nomad
Well, if you are replacing the entire light fixture, you do need to seal it to the side of the trailer, and I have used that "Plas-T-Cote" puddy.. Similar to Plumber Puddy as best I can describe.
It's used for roof vents, but I used it on running lights and rear tail lights when I had to replace the entire thing over the years.. I am still using the same roll I bought 10 years ago.. It's still malleable and seals just fine.
If you are just replacing the lenses, then you don't want to seal that, as mentioned above.
Good luck!
Mitch
Good luck!
Mitch
About RV Newbies
