- dcasonExplorer IIGo the smallest you can live with (unless you like to travel with lots of junk). We use a van (doing art shows) and a 20 foot travel trailer and that is perfect for us. For fun we use a 24 foot jayco class c.
You will fit more places, take less junk (because you cannot fit it).
Buy used and try it out; then if you like it you have a choice. BUT, what's not to like?
donna - ricskinnerExplorerWe're really appreciating all the very helpful guidance that we get from this group. As all of you know, selecting the TT and TV in not a quick or easy decision. We continue to research, visit dealers, and read all your postings. Many thanks.
Ric - wkrpExplorerWe had our TV before we purchased our TT and I'm glad we did. That way we knew what we could safely and comfortably pull.
We have a 2011 4dr. Tundra 5.7L with tow package. Our TT is a Jayco 26RLS that comes in at around 6300lb. dry. This leaves of plenty of wiggle room for all the extras we take.
We are comfortable with this package and are glad we didn't get anything bigger OR smaller. I would much rather tow with ease and peace of mind than have a TT 1' or 2' longer and have to fight it every mile.
Beware when you pick out a TT you like and the dealer tells you there is absolutely no problem pulling it with your TV. Do your homework. - JiminDenverExplorer IIWe have a Ameri-lite ultra lite trailer and love it. That said some ultra lites have weight saving measures that may or may not fit your needs.
Ours is a 3 season trailer without enclosed and heated under belly, less insulation and single pane windows. We are fine if it freezes over night as long as it gets above freezing the next day. Since we don't winter camp, it works for us. Even in the 20s the furnace keeps us warm and only runs 3 times a night.
Some weight saving things have no impact on our camping like the plastic sinks and toilet. We will never know there is OSB in the cabinets unless there is a leak. Our propane tanks are 20 lb instead of 30 lb but we have yet to use one of those in a trip.
OSB in the cabinets is one thing, in the floor is another. Some manufactures use OSB or Luan in the floor and it will eventually sag from use and really give if leaked on. Ours has 3/4 inch ply and doesn't sag even under my 220 lbs +.
One thing I would have liked is larger tanks. 30 gal of fresh water doesn't go far so we take extra and conserve.
For us having the ultra lite means we can have more trailer and not strain the truck as much. It also cost half as much as a nice 4 season model of the same size. Ours seems constructed well enough as it is no pavement queen. We are usually 5-10 miles off the beaten path and NFS roads are rarely maintained well. We cross wash outs, traverse rock strewn trails and ruts to get to those out of the way spots on a ridge.
So make sure the ultra light you pick has the features you need. Replacing a sink or faucet is one thing. A soft floor is a bigger issue. - md2lgykExplorer IIIf there are any near you, I recommend going to an RV show. That's what we did when we wanted to get back into RVing after a number of years of tent camping. You will be able to see pretty much everything that's available, and show prices are usually deeply discounted.
The other thing I recommend is looking for a decent used pickup truck for the tow vehicle. We got a 2-year-old Sierra half-ton crew cab for less than half the cost of a new one. Others here may disagree, but I'd stick to a 2WD. They are considerably cheaper and get better mileage than a 4WD. We test drove several trucks before buying, and the GMCs have a much more "civilized" ride than, say, a Ford F-150. - ncrowleyExplorer IITake a look at the older Evergreen Everlite's that had the "no wood" construction. I had one and it was lightweight and a joy to tow. It was also very well made.
- wintersunExplorer IIIf you have any RV parks or campgrounds near your house take time to talk to owners about what they like and dislike about their current and any past trailers and tow vehicles. Then you can decide if they apply to you both.
To me the most flexible RV setup is a pickup with a crew cab (seats 5 adults) pulling a travel trailer. The truck with a cap can hold bicycles, camping gear, a boat, and all the other items you do not want to hang off the back of the trailer or have to store inside. The rear seat of the cab is great for putting items you want to be able to get to without stopping and going inside the trailer, like raingear, snacks and beverages in a cooler, photo gear, and the like, or pets.
A big advantage of trucks is that they are built for towing and will better handle the trailer in every respect. A 1/2 ton truck will be adequate for a trailer under 8,000 lbs and provide a smoother ride than a heavy duty truck.
You can download trailering guides from all the manufacturers' websites and other sources that will provide exact information on the load capacity of different vehicles. I would not trust a salesperson at a RV or auto dealer for accurate information. - BumpyroadExplorerI would look at the Ascend A191RD. If I had a little more tow vehicle I would have bought that instead of my Ascend A171RD which I tow with my Highlander, not a F-550 as recommended here.
:) bumpy - WoodGlueExplorerIf you're going to be hauling an UltraLight TT, you're probably looking at a less than 4,600 lb TT and almost any kind of SUV these days can haul that load, even a skimpy 6 cyl.
That being said, you should look at a TV, something that will haul something more substantial, say a 8,000 lb TT. This is in case you change your mind about your first trailer and need to "trade up"
I'm all for researching your TT thoroughly and sticking with that choice, however many on this forum will swear by the fact that you'll go through 4-5 TT's before hitting on one that you'll truly like.
I'd suggest that you look at Lance Travel Trailers for a higher end, extremely well built TT. (look in my sig for more info)
Lance Travel Trailers - Ultra Light Weight
I say. buy once and buy well.
WoodGlue - JKQExplorerMost important thing to remember is if you buy the wrong truck your camping experience will turn out to be a camping nightmare! Purchase at least a 3/4 ton tow vehicle & a diesel if $$ allow.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
