This part of the project motor-home is complete!
Summary:
- Replaced water damaged floor and sealed seams with silicone caulking
- Reinforced coach to cab steel connection plate(for lack of a better term)
- Re-positioned fresh water tank and installed new PEX fittings and valves to isolate pump and secured tank to position under couch
- Added PEX line and valve to fill fresh water from city water(kept manual fill)
- Refitted overflow to drain with tank drain and vent to old overflow port near manual fill port
- Installed 2 steel plates to the floor with screws and construction adhesive
- Mounted couch to the steel plates
Solid as a rock!
Time to move on to next piece work, after a brief intermission to take care of some minor things.
