azrving
Jul 09, 2015Explorer
x2 on the 5 inch white vinyl fence post. Mount it where it wont get smeared off by dips in parking lots etc. I used a plastic rain gutter inside mine and push the fittings into the gutter and slide it into the post. I glued ends onto the gutter and drilled a few holes in it for drainage. It slides out as much or as little as you like. I drilled the end of the post and put a bolt through it with a clip.
I mounted mine in front of the tires on my FW. It's right above the drain fitting area.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
