efiguero's avatar
efiguero
Running generator at night while sleeping?
So I've read that it is not recommended to run a generator at night in a motorhome while everyone is sleeping because of the chance of CO poisoning. Is this true? Or is this similar to the debate on how safe it is to run a fridge on propane while driving? I am just curious as I assumed the whole purpose of a generator was to provide electricity to the MH when not plugged in, so if you need AC at night the gen is needed, right? I know in some parks due to quiet times you can't run them at night, but if there is no restriction and you have CO detectors installed in the MH is CO provisioning from your Gen running a common issue?
  • CO is a product of incomplete combustion. A small amount of CO will be generated by a properly running generator. Some of it will likely seep into your RV. More will seep in if there is more created. This is partly offset by fresh air that slightly pressurizes your RV when the AC is running, assuming the AC draws in fresh air on the roof.
    Make sure your genset runs good. Use multiple, newer CO detectors. Follow all the other safety procedures for operating the genset. Use it if you need it and it is allowed.
    Personally, I'm more worried about a genset fire than CO.
