turbojimmy
Dec 13, 2015Explorer
Fla904 wrote:YC 1 wrote:
You can run it that long but why would you need to for that many hours? The refer should be able to run on propane unless it is a residential model. Your alternator will keep up once your battery banks are full.
The previous owner cut the propane line because she was scared to drive with the tanks full.. So it can only be ran on the gen or electric. Just wanna make sure I don't over do the gen.
Because cut propane lines are so much safer? SMH
Like others have said, if it's for the reefer I'd repair the lines. Much more efficient to run it on propane. The generator will run for that long without issue, but why? Really inefficient.
About RV Newbies
