Txsurfer
Jun 13, 2016Explorer
Thanks Gents - My transfer switch is on located behind a hacth on the front of the TH so all I need to do is run about 3' of 50 amp wire from the switch to a twist lock recepticle which I will mount on the foward wall behind the propane tanks - my thought is this area will catch less spray (rain) from the TV while driving. I am thinking the way the go is use a 30A cord that has a 50A lock ring end on the RV side and a std 30A on the Gen side. I think I read that this arrangement will actually only feed juice to one leg of the 50A plug which should provide enough to run my AC. I could run my 50A cord and step it down at the Gen but it's so heavy. Is my reasoning sound?
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
