thehippie's avatar
thehippie
Rusty ball
I Bought this ball hitch less than three months ago and it’s only sparingly used. But I wonder why this got Rusty here pretty quick. It’s even rated 30,000 pounds
Anyone experience this?
Is it still safe to use?
https://ibb.co/6ghfqwW
  • Curt. Enough said. Chinese junk. Advanced auto Parts replaced Reese with Curt. What does that tell you.
  • It's a CURT 2 5/16" 30K rated Ball with a VERY POOr inferior chrome plating job
    plating has flaked off even on no contact syrfaces
    Rust not a big issue.....pitting is and will only get worse
    If purchased at a STORE----return it
    If purchased ON LINE.contact CURT---explain time frame and send pictures
    Bet CURT would be interested in defective plating
  • Rust isn't a sign of inferior metal. Quite the contrary - ever notice bank vault doors have protective shields over the surface? That's because a finger print will cause almost immediate rust on the surface of the hardened metal. Or how fast high end brake rotors rust?
    I would (and do) leave a film of grease over the ball to keep it front rusting or wearing excessively into the tongue.
  • enblethen wrote:
    The ball appears to be pitted around some of the rust. I doubt whether the ball is hardened enough for a rating of 30,000, more like 3,000. It could have been caused by chemical such as salt or other deicing chemicals.
    Make and shaft diameter of ball?
    I agree, it is likely a cheap offshore knockoff. I would not use it.
  • The ball appears to be pitted around some of the rust. I doubt whether the ball is hardened enough for a rating of 30,000, more like 3,000. It could have been caused by chemical such as salt or other deicing chemicals.
  • Gotta grease your balls - especially if they aren't being used. Just sayin..
  • No problem. If you keep a little grease on it that won't happen, but it's not going to affect the performance of the ball.
