bsbeedub wrote:
I only have a 15 amp outlet at home. I use a 25 foot, 10 gauge extension cord to a 15 to 30 amp dog bone, then to my TT power cord. I can run JUST my a/c fine with that set up. I have my multimeter plugged in and when the a/c is running my volts are at 114.
Two problems with your post.
1) Becuase it works for YOU does not mean it will work for everyone. There's different sized of AC's, there's different lengths of wire from the panel to the 15A outlet, and there's different voltages in electrical systems (varies with location and the time of day). And who knows what the other electrical loads are on YOUR camper- that can vary too.
2) The words "just fine". It's a fact that a runnining AC commonly uses less than 15 A and you have your voltiage meter, and that you are using a great extension cord, but at the moment of start up, your AC might be a bit short on electricity and you never know when there might be some transistor thing that gets a bit frazzled.
Maybe if you said that you have a smaller air conditioner and make an effort to limit other loads- but the overly bold bragging is giving bad advice.
