ndanecker's avatar
ndanecker
RV Ski Trips
Curious if anyone has used their RV for winter ski trips instead of renting a condo or house local to the ski area. I found a few RV parks open during the winter months near a ski resort and the Mrs. was asking if the RV would be an option. Of course it would need to be unwinterized if we wanted to use water (which is preferred). Just curious if others did this and if it was worth the effort. How did you address the freezing pipe issue during ride home until you get to winterize the pipes again, or is it possible to keep the RV above freezing for the next trip (lets say 40 or 45*)? I know it would be easier to rent a place but we like our own stuff (and germs). Its more a comfort thing then to save money, but I think that's a given as we all know RVs are more expensive in the long run over renting a hotel, condo or house.
  • The ones we are looking at have a heated underbelly. If you blow the lines out do you also need to pump the pink juice, or can you wait till you get home or the following day? Guess it depends on temp and how long to cool back down.
    I'm surprised mfg don't design lines that completely drain. Not hard to do. Keep dump valves for areas that cannot be designed to drain or have low points.
  • run your rig up and back without any water in the lines
    easy to blow them out with air
    guessing you have a heated underbelly?
