JimK-NY
Aug 10, 2022Explorer II
To sanitize the HW tank, you need to remove the plug, let it drain, replace the plug and fill after adding bleach and filling the fresh water tank. To do this I need to run the water pump for several minutes to fill the tank. Then you need to open the HW faucets and shower to soak those lines and fixtures. After the soak time, you need to again remove the plug and drain the tank. Then fill with fresh water and purge the bleach out of the lines.
About RV Newbies
