TubaPete wrote:
Just asking but what exactly do you mean by "rinse?" Did you run a few gallons through the system or did a rinse consist of completely filling the tank and then completely draining it? And did you drain it at the tank drain or run the water through the system? A complete fill and flushing the lines would be necessary to touch all surfaces with clean water.
I had a similar problem once. While it may be aggravating, I didn't consider the foamy water to be unsafe to drink. Cities add chlorine to their water all the time.
ya, filled, ran through the lines and drained. Have done that at leaset 6 times. Lost count.
I was going to taste the water, but seeing all that foam under the trailer I just could not bring myself to do it.
I still have just over a week to get it right, but it drives me nuts knowing it is there and it was my fault for not reading the label better.
