phxchica's avatar
phxchica
Satellite hook up...what am I doing wrong?
Okay let me just say I hate setting up computers, cable TV, etc. I spent the better part of Saturday trying to get the satellite working. I have the Winegard Pathway X2 and a Jayco Greyhawk. I got it to the point of getting Dish if the receiver is hooked up directly to the satellite. But when I try to connect it through the outdoor cable hookup on the RV, nothing!. Complete signal loss!. Repeatedly checked the connections and still not working. What at am I doing wrong?
  • If you're using an outside cable connection port that connects to the power injector for the roof top OTA antenna, the internal switch that turns it on and off as well switching which source goes to the TV will not pass the signal from the X2. Best fix is to run a separate cable for the X2 to the receiver, but you can also install an A/B switch that will route the outside port around the power injector for satellite use, and still allow using the port for cable when desired.
  • I do not know how your trailer is wired, but if there is a splitter between the outside cable hookup and the connection to the receiver, it will not work.
  • Thanks, I will try it. I do have the R6 cable. Is that something different?
  • I had the same problem, I checked everything, turn out all I had to do was change their white colored cable fitting for the one with the blue inside, something about frequencies that can pass.
    Lary
