Brokentone
Jan 02, 2015Explorer
I had a scraping noise when moving the slide. What I found was that when the hole through the frame where the actuator passes through was cut they left the oblong piece of steel inside the frame. It was able to move a little bit. I cut a piece off of it and it moved towards the rear. All seemed good till it slid forward and the noise came back. I disconnected the actuator, tied it up, tried to remove the piece. It would not come out, I clamped it to the frame and cut pieces off with a sawsall until it was small enough to remove, took about 3 hours. All is well.
Good Luck
Good Luck
About RV Newbies
