rhagfo
Oct 23, 2016Explorer III
allen8106 wrote:
All 50 amp feeds are two legs of 110 volts. All campers are 110 volts. No such thing as a 240 volt camper.
Not true soon to install Cheap Hat and use 240 v 30 amps for heat. The reason you only have 110 volts is the design of the breaker box. The only spot you have 240 volts is at the main.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
