Hank_MI
Oct 24, 2016Explorer
happycamper002 wrote:
What Old-Biscuit is saying, is:
Even though the pedestal provides 240 volt at the 50 Amp plug, the two (240 volt) legs are not used (simultaneously) for appliances that are made for 240 volt operation (unless you are driving a huge Prevost) to run an electric range, electric dryer or huge 4 ton A/C.
As soon as the 50A power enters the RV, it is split into two branches that power two separate buses in the load center.
This is made to balance the load between the two legs when the system is loaded to full capacity.
Utility providers requires this to protect their equipment.
Which is exactly what occurs in the service panel in your house. One hot leg feeding one buss and the other hot leg feeding the other buss. If you had a gas clothes dryer and gas stove and perhaps no central AC would your house then be considered a 120v house? No it's still 240v.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
