Desert Captain wrote:
You will find a dual axle trailer much easier to back and maneuver in addition to the many good reasons listed above to own one.
:C
Irrelevant. The length of the trailer (from hitch to axle(s) is what determines backing and manueuverability, not the number of axles. Longer trailers will react slower and smoother to input from the tow vehicle, and shorter will be react quicker and be more maneuverable. Tandem axles will track a bit better and ride a bit smoother, but will also "scrub" the tires when turning tightly and are therefore more likely to damage the sidewalls. A single axle trailer is also more sensitive to weight (front/rear) loading affecting tongue weight.
