donn0128
Nov 17, 2018Explorer II
First off. Right at the water pump there should be a hose and a valve. Turn the valve, stick the hose end in the jug of AF. Be sure the valves behind the water heater are set to bypass. Turn on the water pump and go inside and open one faucet at a time until you see pink.
As for closing the slides? As long as the snow is brushed off the slide room roof, close it up. No big deal.
About RV Newbies
