SidecarFlip
Nov 17, 2018Explorer III
donn0128 wrote:
First off. Right at the water pump there should be a hose and a valve. Turn the valve, stick the hose end in the jug of AF. Be sure the valves behind the water heater are set to bypass. Turn on the water pump and go inside and open one faucet at a time until you see pink.
As for closing the slides? As long as the snow is brushed off the slide room roof, close it up. No big deal.
Only thing your forgot is...start at the farthest tap from the pump and work back. and don't forget the outside shower if it has one... Dump the black tank and grey tank and add a spritz of RV red in each too.
Takes just a gallon with mine.
About RV Newbies
