Houndguy wrote:
Power is not the issue. Water and Septic would be, although I can't imagine it be that difficult to tie into the lines if needed. However if we do that then we might as well just put a basic mobile home in.
Water is easy - just run a hose from an outside faucet to the RV city intake OR use the hose to fill the fresh water tank as needed.
The septic is your biggest concern. If you have a convenient clean out, then no biggie; if you have a clean out, but it's not convenient to the RV, you could use a macerator - trying to use regular dump hoses in these situations is a pain and can be messy... If you don't have a clean out, then you have to look into adding one or going to dump stations.
