BSawyer321
May 19, 2019Explorer
So many questions!
I recently purchased a 1979 Midas travel trailer. I have no experience with campers or anything related and knew it would be a project. I have so many questions!
1. When I purchased it there was some water damage on the ceiling at the front. I tore down the damaged sections and will need to replace. When I tore it down it was wood, foam, wood. This is how I plan to put it back up. The rubber molding between the wall and ceiling was cracked and broke in pieces so i assume that will need to be replaced. What is this called so I can find some to replace it? Does it have to be replaced? We will be resealing the roof as well
2. Water tanks: I understand the tank under the camper with the valves for drainage is for the dark water or sewage, but there is a smaller blue one in in the camper. It has a connection to it from the outside labeled "city water hookup", is this for the fresh water? It has to be replaced d/t a giant hole, but I'm trying to figure out the purpose of the tank. Does water go in there for shower, sinks, toiet, etc, then cycle through the trailer when the faucets (sink, shower) are turned on? Do you have to turn off the water from the outside once the tank is full? Doesn't seem like it would hold enough water for a shower if water isn't constantly fed into it.
3. There are other exterior and interior pieces that will need to be replaced is there such a think as an RV or camper junkyard you can go to and pull these parts? I'm in central NC.
4. The wiring is a mess and will have to be redone. Any tips or guides for this? My husband is a certified electrician but has never done anything like a camper. What do we need to know about the fuse box, etc? A lot of the lights were torn down in the demo of the inside (not by me) what do we need to know about wiring and replacement lights?
5. The A.C. Is there, no idea if it works. They said it did but who knows because we haven't had it hooked up. If it doesnt, repair or replace? I know replacing can get expensive. There was once a heat source-there is a gas line that runs to a compartment in a closet, what do we need to know about purchasing and installing a new one? There is a thermostat control on a wall that I assume connects to the area where it once was.
