tfirma
Oct 14, 2013Explorer
Some Beginner questions (weights, trailer length, etc.)
Hello!
This forum is a fantastic resource - a big thank you in advance to all of those folks taking the time to help us newbies! :)
I did search around for some answers to my questions below, but in some cases I still wasn't 100% sure, so I will post some below (my apologies since I know some of these have been asked many times before!)
Regarding weights/limits/etc. I am looking to purchase a Range Rover that has a towing capacity of 7,700
If I understand correctly, the Dry Hitch Weight is the part of the weight of the trailer that should be added to the weight capacity of the towing vehicle weight? So, if I have 1,700 lbs of "carrying weight" to play with on the vehicle, do I immediately subtract the 700lbs of dry hitch weight listed in the trailer specs?
So - I have to concern myself, primarily with the "fully loaded" weight of the trailer (UVW + any cargo) and then the weight of my towing vehicle (GVWR, to include the dry hitch weight?)
I was happy to see that many of the trailers that interest me are under 7,700 lbs, GVWR, but I see MANY different opinions across the forums on the practical usage of these specs. I've seen some folks say never to tow more that 80% of the weights seen in the specs. So my 2nd question is for folks that might also have used/seen an SUV tow a larger trailer... Generally speaking, how difficult of a prospect is that in reality?
Moreover, from reading the posts of others, even if I am within the weight restrictions, a trailer that is close to 30' long hooked up to a considerable shorter tow vehicle sounds like it is VERY problematic. I know it's the classic question/trade-off, but because I don't want to "white knuckle" my drive, do folks here think it makes sense to stick to a trailer closer to the length of the tow vehicle?
Thanks very much - I'm anxious to go get my new towing vehicle and trailer, and your advice is very much appreciated! I'm not looking to get a truck - I really need to stick to the SUV for other practical purposes, so my decision mostly hinges on having an SUV (if not the Range Rover, something else) that probably maxes at around 7,700 towing capacity.
Thanks again!
Tom
Thanks again!
Tom
