anaro
Oct 14, 2013Explorer
You need to know more about your trucks capabilities than just my truck can tow x lbs. (I learned this the hard way). Most TV are limited by their payload. To find out your TVs true towing capacities then you need to go weigh it. Load the tv up with all occupants, pets, and cargo that will be in it when towing plus a full tank of fuel and then go weigh it at a local scale (www.catscale.com). Weigh each axle on a separate scale pad so it will give you a breakdown of front and rear axle weights individually and a total weight. Take the total weight and subtract it from your Trucks gvwr to get your available payload. Take the scaled Truck weight and subtract it from your Truck gcwr to get your adjusted towng capacity. Not owning the truck, you can look at the sticker inside the drivers door. It should say "occupants and cargo not to exceed x lbs". take the weight and subtract the weight of you, any passengers and pets plus any gear you plan to have in the truck when towing. The number left is a rough estimate of your available payload. You need a loaded tongue weight less than this number.
Now understand you will never tow an unloaded or dry trailer. Those numbers are somewhat irrelevant. You can either add the amount of weight of cargo you will tow to the dry weight (this is heavier than you think as most add 1000-1500 lb of gear) or simply use the tt gvwr to do your calculations. (for your purposes do all weight calculations using TT gvwr). Next understand that the tt loaded tongue weight needs to be subtracted from your available payload. The loaded tongue weight is typically 13-15% of the loaded tt weight. The dry tongue weight doesn't even include propane or battery. Also anything placed in the trailer in front of the axles will add to your tongue weight. For your purposes 13-15% of the TT gvwr will be an easier calculation to figure out.
An example here (totally made up numbers from fictional vehicle).... curb weight on scale loaded with passengers and gear: 8500 lbs. TV gvwr 10000 lbs. you have 1500 lbs available payload for a loaded tongue weight. On the fictional trailer, there is a dry weight of 5700 lbs and gvwr of 7700 lbs. Said trailer actually scales in at 7000 lbs loaded. 15% of the loaded (7000 lbs) weight is 1050 lbs. Fictional truck may also have a door sticker that says occupants not to exceed 1700 lbs but with pets, passengers and gear you are down to 1500 lbs available payload.
About RV Newbies
