We have a 2013 Cougar XLite 30FKV TT. Purchased new in Nov.2012. Floor has numerous spongy spots throughout trailer. Talked to dealer about possible solutions, not much help. Thinking of putting n...
in order to save weight, manufacturers of "lightweight" units do things like use thinner subfloors and spacing out the floor supports further, thus having less supports. Look under trailer and prob will see one support every 4-6 ft. You can simply weld in some angle iron across the width of your trailer to give more support. Adding more weight (ie plywood floor) to a floor that's already weak only makes it worse.
