CMunrock's avatar
CMunrock
Stabilizing hints please....
I have an 31' fifth wheel bunkhouse model. The bunks are in the very rear and when the kids even turn in their beds, the entire unit shakes. I stabilize the 5th wheel with the rear scissor stabilizers and 4 of the standard aluminum threaded stabilizers. I also use the X-chocks.
It's not a huge deal that it moves, but I thought I'd check if there's stabilizing insider secrets that might help me sleep in a little longer. Thanks!
  • JT's WILL eliminate majority of movement.
    Where are you using the 4 aluminum stabilizers?
    Froward & rearward of tires should stop the 'bounce' effect from suspension
    One thing I do is level F to R using landing gear then lower them (the legs) about 1".....set rear stabilizers snug then raise front legs back up the 1"
    Makes 5vr stable.
  • Install some strut type stabilizers such as JT Strongarm or similar. Eliminates most of the movement.
