Mickeyfan0805
Jul 18, 2013Explorer
2gypsies wrote:
You didn't state how long your RV is but if you have gas, the car fill-up area is your only option. The truck area only has diesel but RVers are welcome to use it also - for diesel.
Try to grab one of the end pumps where you'll have more room - at least until you're a little more experienced. Also, if you're on the interstates, you could use the rest areas for the pit stops and lunch then you wouldn't have to find a place to park and wait at the fuel station.
You could also park in your campground, unhook and drive to a fuel station w/o the RV to refuel before you start out in the morning.
It'll become easier and easier with more experience. Just take your time in the stations and look over the situation BEFORE you get trapped in a situation where you can't get out.
If you have 'The Next Exit' directory for interstates, there is a symbol next to the fuel entries that will tell you if it's recommended for RVs. That would be a big help. Also, as stated above, some truck stops have special RV pumps for both diesel and gas and also propane. You'll find these at Flying Js, Pilots and others. It just takes some advance planning on where you figure on stopping. Don't wait until you're almost on empty. Strive for filling at 1/2 then you'll have plenty of leeway for finding the best station for you. Good luck!
In some cases, there is gas on the truck side (which is the reason for my post, I was simply wondering if there was a way to know in advance whether or not it is there). I've used them on a number of occasions. It doesn't look like it's all that consistent, however.
We do have Next Exit, but honestly, I find it to be relatively useless. Perhaps it is the regions I travel, but it is not at all uncommon for us to look for their rv-friendly options and find absolutely nothing within 50-75 miles or more. Given how often it is recommended, I find myself wondering if it is more useful in other regions.
About RV Newbies
