loneryder's avatar
loneryder
Stuff sliding around on shelves
I feel like this is a dumb question but the shelves on my new Four Winds have slick floors. I have installed that foam shelf liner but it just slides with everything on it. Is there anything out there that will stop stuff from sliding around? No sense in having organized cabinets when everything just piles up inside.
  • It's a new MH so tires are good. The bottom of the shelves are a slick finish. I'll try tacking the liner down.
    Thanks all.
  • You might try using some museum wax or even a couple well placed thumb tacks to hold the liner in place - if it doesn't slide, then your other stuff is unlikely to do so.
    Also, I have found the best solution is to fully pack the shelves. It's better to have 3 full cupboards and 3 empty, than it is to have 6 half-filled cupboards.
  • The foam liner has worked well in ours, but sometimes will use some "filler" items such as the smaller boxes of Kleenex, a roll of toilet paper, empty juice bottles, or other such items.
    Bill
