Dr_Quick's avatar
Dr_Quick
Explorer II
Sep 12, 2017
Suburban furcance prob lem
My furnace will light and run for about 5 seconds, then quit for maybe 30 seconds and try to light again. It does this 3 times then shuts down. You can turn off thermostat and it will cycle and keep on doing the same thing again.
Have you had this problem and want what was done to solve problem and get furnace running again
Thanks
Additional information: Trailer is only just over 2 years old, so furnace is out of warranty. In that 2 years we have camped say 65 days and maybe used the furnace 15 or 20 nights.
I did one test of the furnace where I turned on all three stove burners then turned on the furnace to see if gas pressure would drop. but when furnace lit for a few seconds, gas flames on stove never changed. So I do not think it is a gas or regulator problem.
  • Mr. Biscuit will be along and diagnose your issue and tell you the proper procedure to fix it.
  • Long shot.
    I had this problem,
    the service guy found a small knat (bug)
    in the orifice.
    He said this is very common!
  • 3 rimes and it locks out. That is SOP. Could be as simple as a bad thermoswitch or could be the sail switch is hung up. It's not sensing the flame so it's shutting down and starting again. 3 times and it's done.
