Happy_Camper3's avatar
Jul 11, 2015
Tandem axle camper, driving with a flat
Hello,
So I drove 96 miles from my house, to where my camper is on my land up north.
With the intention of then grabbing my camper and bringing to a local dealership 17 miles away.
Got out of my dirt driveway and 30 feet down the one way, non maintained narrow dirt road, and checked the camper over.
Saw the rear driver side trailer tire was flat.
Took a tire gauge and measured 0 psi.
I can't back it 90 degrees downhill on a driveway that leaves 6" of room on each side, maybe you guys can, but I can't yet.
Long story short I risked it, and drove 40 mpg 17 miles on a flat tire. Made it there and everything was fine.
Tires say 2800 lbs max load each. Trailer was probably 7000lbs.
So two tires on one side, and one tire in the other, I am sure I was over load limit for tire.
Anyone done this before ? Should I have parked and called a tow truck ? Didn't have tools to do it myself, and would have had to walk 5 miles to cell service, or leave the camper blocking the road?
Thoughts or opinions ?
Is it ok to drive on one tire ? Or do you guys stop driving immediately until it's fixed ?
  • As long as the one tire was inflated properly I would not change both of them. Speed makes a big difference. I probably would have gone a little slower. Did you feel the tire to see if it seemed over heated once you arrived. JMHO
  • As long as the tire didn't come apart, you made out ok. But as John said, the other tire was way over loaded and needs to be replaced also.
    Ron
  • I had a flat and didn't know it for a while. No harm..
  • You did what you had to do but if it were me I'd replace both tires on that side,
    so it cost you two tires instead of One
