harmanrk
Jun 12, 2017Explorer
The plastic under the trailer, and cross members.
Trailer is a Solaire (Palomino/Forest River) 190X, Hybrid with slide.
Are the plastic panels needed? Other than keeping dirt and debris off the tanks and wiring, does it do anything?
While hooking up to come back from camping this past weekend, I noticed one panel has a bit of a sag to it, and when looking closer, found that a few of the self tapping bolts that hold it in place have worked their way out over time.
This also lead to a bigger discovery. Just above and behind the rear wheel/axle, and just in front of where the grey water tank outlet is located, one of these self tapping bolts has had it head snap off, but it is not just holding up the plastic panel, but also goes though some sort of cross member (appears to be about 1 inch round tubing that goes across the trailer.). The cross member appear too small to be structural to the trailer, but I'm thinking with the location to the grey water tank, it may be a tank support.
Anyone have any information on what the configuration under these trailers is? I assume I'm going to have to either take it to a dealer for service, or remove the plastic to find out what the cross member does, but I'm not sure the plastic panels will be reusable after I remove them.
Thank you for any information you may have.
