JimK-NY
Aug 13, 2020Explorer II
Covers provide minimal protection. Sure they protect against UV rays but that still leaves dry rotting due to oxidation. I learned that when I tried to use a tire that had been stored under my pick up for 4 years. Obviously no direct light had ever hit that tire. Even so it was dry rotted. It looked OK until I put it on the truck and left it for a few days with my camper loaded. By then cracks appeared everywhere. Subsequently I learned tires need to be used. Chemicals embedded in the rubber work their way to the surface and provide protection.
Another option that has not been well studied is the use of Aerospace 303 protectant. This will provide some sealing against oxidation as well as providing some UV protection. 303 needs to be replaced every few weeks. In addition you need to start with clean tires and coat both inner and outer surfaces. Avoid getting too much on the thread as it will cause loss of traction.
About RV Newbies
