SCADAMAN29325's avatar
SCADAMAN29325
Explorer II
Apr 22, 2023
Tire covers?
Firstly do tire covers help, not much or a lot?
What should I look for when buying tire covers?
Any recommendations on which ones to buy or stay away from?
Thanks, Phil
  • Understandably heat/UV affects tires and will cause dry rot but the real issue is sitting. Tires that are exercised regularly continually to stay flexible and release oils and compounds that resist dry rotting. I would love to see any evidence to support tire covers on tires just sitting. I doubt they have any real benefit to tires that are driven on regularly. So if your RV sits for long periods of time in the sun, they will probably offer a minimal benefit. How much is an elusive question. If you drive your rv frequently it's probably a waste of money.
  • Scadaman,
    This is a paraphrase of the answer that I got from Roger Marble some years back while at an FMCA convention.
    Tire covers can help, but it is not the UV that is the issue, it is the heat. So, have white tire covers and be sure that they are on the sunny side of the RV. New compounds are not very UV sensitive, but heat is the enemy of tires and the sun is real good at providing heat.
    Matt_C
