wa8yxm
Nov 28, 2016Explorer III
The difference is small enough and the nature of RV tires is such that it likely won't make much difference...
First: you gave the sticker weight, the sticker pressure,
The acutal weight and pressure
You did not give the recommended pressure for that weight (You get that from Mitchiln and be advised that the two ends of an axle may be DIFFERENT.. yup)
The proper pressure or perhaps a few (5) PSI more gives the best control under less than ideal conditions, a good ride and the best tread life.
RV tires almost never run out of tread (They run out of calendar life)
Slightly high si not an issue but I'd likely take 'em down to at least 100, if not 90.
About RV Newbies
