lanerd
Mar 23, 2017Explorer II
DarkSkySeeker wrote:
My friend sold his Class A and offered his TPMS to me. His Class A had huge tires, but my TT has much smaller ones. I asked him if the weight of the sensors require me to rebalance the tires. He said he had not thought of that. But the web pages I reviewed suggest adding a half ounce weight to the side of the wheel opposite the sensor. So I declined them. It is not that much of a hassle but I declined anyway.
You do realize that normally if you have a low pressure tire, it will eventually get hot or break the bead on the tire and it will come apart....taking large chucks of your trailer's wheel well and siding along with it causing hundreds of dollars worth of damage? The same with a blow out. Most never know they have a tire problem until someone comes along side of them and gets their attention. Not having a TPMS system is just plain silly.
If you're worried about the sensors causing your tires to become un-balanced, why don't you just take them down to the local tire shop and have them rebalanced with the sensors on them? The cost would be much, much less than the repair costs if you have a tire problem.
Simple and cheap.
Ron
About RV Newbies
