lanerd
Mar 24, 2017Explorer II
crasster wrote:
I like TPMS and have used them in times past. I don't anymore, not because they are bad, but because there are so many complications to the RV anyway. Here's what I do. Before I trip I check my pressures. If it is a 2-3 day trip, I do it once. That's it.
If it is a long cross country trip, I check them before I go. Then after my destination is reached, I check them before I come back. I have a 12V tire pump to add pressure if needed.
I do think it's a good method.
That's all fine and dandy...but what about you're traveling down the road and you pick up a nail and the tire develops a moderate leak and five miles down the road, it gets so hot, due to low pressure, that it comes apart with chunks of tread flying off taking out hunks of fiberglass, fender skirts, wire bundles, brake lines, hydraulic lines, fuel lines and what ever else that happens to be in the path of the tire chunks causing hundreds (maybe thousands) of $$ damage? No problem tho, you checked the pressure three days ago and it was just fine.
About RV Newbies
