timpitt's avatar
timpitt
Explorer II
Aug 20, 2022
tire pressure
We have 2021 fleetwood bounder 33c what is a good psi for the tires
when loaded We will be towing a Ford ranger.
  • Towing a Ranger, not towing with. A Bounder is a motorhome.
  • Until you get it weighed, go with the pressures listed on a placard in your RV, or use the axle weights on the placard and use the tire manufacturers charts.
  • USAFBILL wrote:
    Towing with a Ford Ranger might be an issue.
    he could tow your 2500 with no issue
  • Towing with a Ford Ranger might be an issue.....sorry misread
  • It should be listed on the door sticker. With no other information inflate to the maximum on the sidewall. To really set it right you need to weight the RV fully loaded and get axle weights. Then, look up your tires on the manufacturer's load inflation table and inflate to the pressure for that weight.
