atomlinson's avatar
atomlinson
Tires! (yes, tires, again...bear with me)
Hi gang. I know, I know, another tire subject. But I need help. Yes, I used the search feature, but didn't quite find what I was looking for, so here goes:
I'm getting ready to purchase new tires for the TT for our big haul to Florida in June (week 1 will be at Disney- Ft. Wilderness, week 2 will be at Camp Gulf in Destin). I still have the original tires on, so time for some new skins. Size 225-75-R15, "D" range. Looking at different brands, including, of course, Maxxis.
My question: Can I go from a "D" to an "E" range tire? I saw where the max air pressure is greater in an E as opposed to a D, and thought I read somewhere about it depends on how much pressure your rims will allow. I figured more is better, so I was leaning towards an E tire, but don't want to get more than what my rims will allow.
Ok, another question: Plys. Is a D tire considered 8 ply, and an E tire considered a 10 ply?
Thanks in advance. I greatly appreciate any help. Be gentle.
  • Back or inside of rim will have psi stamped, if they are rated for max 65psi it would be best to stay with D rated tire and Maxxis would be your best bet as ST tires go. Got 5 years out of my last set of Maxxis ST tires in your size and our rig is about 10K# loaded for travel. Best to run ST tires at or near max psi, much lower and they will overheat leading to premature failure.
    Thought about going to E rated myself but rims would not support 80psi and the D rated Maxxis tires could handle over 10K# anyway. If your rims can handle the 80 psi go for the E rated Maxxis. Not sure about amount of plys but the E rated tire is heavier than D rated which is heavier than C rated and so on. Have a great time in Florida and at Disney!
  • The trailer we just sold came new with D rated ST tires...something called Missions.???
    We replaced them with load range E Maxxis. We did not replace the wheels. Worked great. No tire problems for the 5 years we had them.
    I ran them at 75 psi.
  • PSI rating should be stamped on the rims. If not, then there should be enough stampings that you can do a google search and ask them. Remember tire load ratings are at full rated pressure. Most tire mfgs will have a load raring chart that will show you load at PSI.
