RCMAN46
Nov 05, 2014Explorer
tvman44 wrote:
Never had that problem, either with my 510 or 507 system.RCMAN46 wrote:
The only issue I have with TST system is it takes 1 hour before the system will notify you of loss of communication with a sensor.
You have and may have and not known it.
If you have sensors on a 5th wheel note next time you go some where without the 5th wheel. When you get out of range of the 5th wheel sensors it will be 1 hour before the receiver will notify you of loss of communication. I have found you can clear the alarm by turning off the receiver then turning it back on.
Thus the problem. If you have a sensor that is marginal it may not be communicating. All it has to do is establish communication once each hour as the timer restarts each time communication is established.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
