LewTeam wrote:
Hello everyone. Just retired in December and once we get a couple of things paid off we plan to purchase an RV hopefully early next year. My question this afternoon concerns a potential health issue. I have some pretty bad knees and am facing probably a knee repair soon. If it can't be repaired I may be facing at least one total knee replacement. What are some issues that you all have faced concerning camping with either needing knee replacement, or, camping after having knee replacement?
Thanks ahead of time. I always appreciate your information and opinions.
Mike Lew
I have no direct experience camping, but am now 10 weeks out from a knee replacement and can tell you some things that are very important.
*Go to a surgeon and facility that do a LOT of knee replacements. Your surgeon's skill is the single biggest factor in how you do. If you are in the Nashville area, go to someone at Southern Joint Replacement Institute.
*Do your pre-op exercises. It will help a lot after the fact.
*You will be in the hospital 2-3 nights, depending on the time of day you have surgery and your general condition.
*Standard practice is a nerve block with oral pain meds on board before it wears off. At no point should you be in extreme pain.
*STEPS are not a good thing. You will need to minimize the amount you do, and do them 2-footed. They should teach you how in the hospital. This could be a factor getting in/out of your RV. You will definitely need a good hand-hold. Step DOWN with the operative leg first and UP with the good leg first.
*You will have a circulating ice water cold pack to use at night. You will need freezer space to freeze about 10 small water bottles to use with it---some to freeze and some to use.
*You will need at least 2 re-usable cold packs to use during the day. You will also need freezer space for these.
*Do EXACTLY what you are told to do so far as meds, exercises, etc. If you have questions, call your dr.
*You should expect 6-10 weeks physical therapy, 2-3 times per week, plus exercises to do at home on the days off. They won't be fun, but should not be extremely painful.
*At the end of PT, you should have 0-120 degrees range of motion in the knee, plus good strength. You will still have some general soreness, and be uncomfortable if you do too much. But you will be better than you are now!
*Don't put off the replacement if you need it. The longer your leg is weak, and the longer you walk incorrectly to favor it, the longer it will take you to get to 100% after surgery. If it's inevitable, go ahead and do it.
Good luck!
