kimberlysmoore
Jul 04, 2015Explorer
westend wrote:
A wire won't leak fluid. Rub your fingertips on the fluid or damp area. Rub your fingertips together. Is it oil or water? My guess is that you have a leaking hose or fitting in your hydraulic system adjacent to that mechanism.
the wire is not leaking fluid. thats a slightly different issue that i found looking for the leak. the second picture shows the hole where the spray came out with fluid like oil. the hose coming out the right side is not connected to the leveler. it turns out its probably not related to the leveler.
ive checked all fluids, all levels are good.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
