obiwancanoli's avatar
obiwancanoli
Tow Dolly Vs. 4WD
As a new RV'r, I hadn't considered that my front-wheel-drive vehicle would require a Tow Dolly, if I wanted to bring something easier to get around in at various stops. Having experienced a few trips using the dolly, I'm seriously considering the convenience of changing out for a 4WD Pick-up which has a bed large enough to accommodate my Harley, too.
I'm hoping to find tips, advice, guidelines, etc., as I'm a 1st timer, and have yet to take my first road trip. I realize, and expect, that I'll also acquire a lift mechanism (where? how much?) to pull the Harley up into the bed.
There are lots of 4WD's out there, and I'm considering something used, perhaps in the 20K range. Both Jeep & Chevy have been suggested, but I've never had a 4WD, so am a novice at this as well...
Sure would appreciate some input... thank you!
  • Well, let’s add up the numbers..
    You have a 35’ Class A, which I assume is a gas coach. Usually the following would have a 5k hitch.
    In order to take the harley, you would need a full size truck... 4800 lbs.
    Harley weighs, average, 800-1000 lbs.
    If you have a 5k hitch, you are already at max towing the truck alone, without the bike, and definitely will be over the GCWR of your coach.
    Good luck with your decision
  • Jeep is probably the most commonly used but you wont put your Harley in that. I have seen both Ford 150 and Chevy 1500 flat towed many times. I am not sure that they have the capacity to haul your Harley either. That is a lot of extra weight to haul in the back of the truck and flat tow. Thinking I would have gotten a Toy hauler if you want to take all that along with you.
