ReneeG wrote:
Time will tell for sure. As did our last ones that lasted 4 years.
Would it do any good to give you the name of the national RV tire experts that are all over the web? No, you've got it in your mind to believe what you want.
Yes it would be perfect for you to give the "national" RV tire expert(s) that are "all over the web"....a lot of  so called "experts" on the web doesn't mean much unless they can PROVE they are just that, "tire expert"..We have several experts on this forum whom I would trust due to their expertise in the tire field and I too know a little about the industry as one of the products my company produces is tires/ I believe in data...I believe in facts, not "hear say".
Your 5er has a GVW of 14,000#. I would think it has 6,000# weight rated axles, "E" rated tires, I personally would have went with a Michelin XPS RIB (pricey, but how can one put a price on safety and peace of mind), or the Duravis R250 (believe that's correct, "me again" could correct me if wrong)...two tires far more robust than the Tow Max tires, don't believe me, go to a tire store, pick up a Tow Max tire like you have o your 5er and check sidewall thickness, see how heavy it is..now pick up a Michelin XPS RIB and check ridigity of the sidewall...proof is in the pudding:)
