lanerd
Sep 24, 2014Explorer II
NekkidFish wrote:
Thanks Ron. From everything I'm reading on here, I have a feeling that doing a TT isn't going to be the route for us with this truck. :(
Don't be discourage... you can still pull a decent sized TT...you just gotta be careful to match it up with your Tundra. I don't remember if you said it had the 5.7....but if it does, it will have plenty of power to pull whatever you can find that will not overload the truck. I pulled a 25' TT with a loaded weight of 5600 lbs for years with my Tundra. I just had to be careful what i loaded in the back of the truck. Also my TT was a rear kitchen which are notoriously rear heavy and consequently had a light tongue. I did have some problems with sway due to this, but I purchased a used Hensely Arrow WD/SC unit that totally eliminated this problem.
So, look around and don't just take the word of a salesman...look for all the necessary weights and make a wise decision.
Good luck
Ron
About RV Newbies
